gadget_lover
Yes, like John1701a says, it activates a mode to simulate engine braking. It first uses regen braking, and then engine braking if needed. If the hill is long enough to switch into 'B' then the battery will probably be topped off before I hit the bottom.
The B mode only delivers poorer milage (wastes power) if you are in a situation where you could have coasted without touching your brakes. I find going 80mph down-hill in the mountains a bit too scary.
I use D all the time except when going down long grades of more than 3% or so. There are some long downhill runs driving into California from Nevada and Oregon. Some of the grades are many miles long. I set to 'B' and then set the cruise for the speed limit and forget about it.
As Darell says, coasting is a beautiful thing. Regen braking catches SOME of the energy used to accelerate, but not all. Coasting does not waste any extra energy.
Using B in normal driving is kind of jerky (especially in comparison to the normal Prius drive), as the car will try to slow every time you take your foot off the gas.
Brock; if you have 20 miles at 42 mph you'd love the Prius, I understand that's about THE sweet spot for fuel economy in the 2001-2003 models. You may be suprised at your milage if you can borrow a car.
My milage is killed by the fact that my normal drive always starts with 1 mile of city streets (with 3 stop signs) followed by 5 minutes at the coffee hut drive through. If I killed my coffe habit my milage would skyrocket.
/ubbthreads/images/graemlins/smile.gif
Daniel
Daniel
