Wattnot
Umm, thanks man, but I do know how to use a multimeter. Looking for tips on measuring the TK40 however. In particular if theres a significant parasitic drain or my alligator clips have too much resistance.
You Sunday multimeter drivers are NOT losing your minds. There is an explanation:
I just tried to measure the current from the bottom of the battery carrier to the nearby threads. The light came on but the meter showed NO movement on the 10 amp scale. I thought my good old Simpson was broken! Then I studied it some more and discovered that the main power comes from the TOP of the battery carrier (head side), both positive AND negative. The bottom plate is negative but evidentally used only for switching the logic circuitry. I'm going to have to carefully insert rods down the body to take accurate current draw measurements, which I will do if I can. This explains the parasitic drain, to me at least.
