Re: H5CC driver
First prototype of the new h5cc layout. Even though it is based on the hyperbuck design, I decided to make some component changes to improve the usefulness for folk that are looking for a round driver that would fit a D mag.
The driver also has a very low Rdson FET for reverse polarity protection. I have put polarity protection into all my recent drivers (fatman is currently the only driver I make that doesn't have it) since too often the owner or someone that borrows the light puts batteries in backwards and destroys the driver.
The PCB is 1.2" in diameter, with all components on the top side to ease heatsink mounting requirements. Basically a piece of thermal pad material or thermal adhesive tape will allow it to mount down to a heatsink.
The precision multiturn trimpot is the same one used on the hyperboost/hyperbuck drivers and allows setting of the output current. There is a buffered PWM control input (high going signal will turn off the output). There's also 2 inputs that allow wiring to an external Pot (in parallel with the onboard trimpot) for continuous output current adjustment.
This driver could be directly connected and controlled by a d2Flex driver.
The following picture shows the prototype driver.
The following shows the driver connected to 6 P7's in (3s2p) to mimic 3 x SST50's in series.
The output current is adjusted to a very low level to allow capture of the picture. A US quarter for size comparison.
More testing to do before I run production boards.
cheers,
george.
