HoopleHead
How have you programmed your new HDS Ra Clicky? :thinking:
Same topic as for the 120P.
My Ra-140-Cn :naughty: settings -
Primary Setting [click]: 0.07 lm (Level 1, lowest)
Secondary Setting [double-click]: 1.1 lm (Level 9)
Low Setting [triple-click]: 100 lm (Level 22)
High [press-hold]: 141 lm (Level 23, highest)
Force Setting: Enabled, Primary
Button Lock: Disabled
Automatic Turn Off: Disabled
Locator Flash: Disabled
Momentary: Disabled
Customization: Enabled
Love it. :devil:
This is my non-tactical setting (i.e. high isnt the primary, and no momentary). Comes on at the lowest low, with the high just being a press-hold away. Secondary is the double-click setting, if I need a bit more light. It says 1.1 lm but I can't believe that really, its not a whole lot dimmer than the E01 so it seems more like a few lumens at least? In any case, enough for most closeup work. Then the high setting is triple-click, harder to get to since my main intent is to conserve battery life, but there if needed. Didn't set it to the very highest again for battery savings, and so I always have a little more lumens in reserve if necessary.
Momentary: Disabled
Love it. :devil:
