callmaster
I've kept factory settings for both the 140CEgt and the 170Cn so far and it serves me well.
140C Settings
Primary level (double click)- 50lm
Secondary level (double click) - 8.8 lm
Low level (triple click) - 0.14lm
High level (click, press hold) - 140/100lm
Force Setting: Disabled
Button Lock: Enabled
Automatic Turn Off: Disabled
Locator Flash: Disabled
Momentary: Enabled
Customization: Enabled
The rationale behind it all.
I decided that 0.3lm was just a bit bright for operating on just awoken eyes, I did a test and night, and found 0.14lm to be perfect for my eyes. 13lm was a bit too much for indoor, and general all around usage, so I decided on a level lower, and that seemed to work perfectly for my needs. 35lm was not quite enough for my outdoors usage, so I boosted the output up a level, and 50lm seemed to work perfectly. Then I left the quasi two output level 23 as my high level for when a lot of power is required. Similar to Jeff, I mess around with customization rather often, so it is best to keep it on for me. I prefer to control when my light is locked rather than having it turn off, so I keep button lock on as opposed to automatic turn off. Force setting bothered me, so I turned it off, and as a general rule, the locator flash is too low to me of use to me, so I keep it off as well. Those are the settings on my clicky! :thumbsup:
I have a Ra Clicky 170 Cn.
I am not able to customize the settings?
I am following the procedure in the manual.
What could I be doing wrong?
Thanks....
:thinking:
I've been playing around with the customization for awhile and I can't seem to decide what brightness setting to use. Right now I have A-Max, B-35, C-6.3, D-0.3
One reason I'm having a hard time deciding is I don't know the runtimes for each setting. Of course that would be a MASSIVE undertaking with 23 settings of course so I guess a really good guess would have to do. I've thought about bumping up the 35 to 50 and the 6.3 to 8.8 or 13 for a low general purpose beam. I also thought about bumping up the .3 to 1.1 - like the older L1 used to have. I'm wondering how much runtime each of those setting would have. I'm sure the 1.1 setting would be probably like 80hrs or more. I played with the strobe but deemed it useless for me.
Anyone else have this problem? Not being able to decide what setting to have?
