AlexGT
Hi all!
A few weeks back Icarus offered a Mag C module using a Cree led here
http://candlepowerforums.com/vb/showthread.php?t=154732
I got interested and PM'ed him about doing a similar project using a SSC P4 U bin and for driver a BadBoy set at 917ma since the SSC can be focused better in the mag reflector and the BB can use regular alkalines or Nimh for longer runtime.
Well, I just got the module, and OMFG!!! It is the brightest single led I have ever seen period! Here is a comparison against the well known Lumapower M1, using 2 x 123's, I would say more than double the brightness of the M1! Even with the camera set at -2.00 exposure, the SSC Mag stomps the M1 with smooth reflector.
SSC on the left, Lumapower M1 on the right
I edited the pic to turn the brightness all the way down, still you can see the SSC Mag on the left stomping the M1 on the right
I compared it against a FM 2.25C Mag with 2 inch deep reflector and ceramic socket using a Magcharger bulb being overdriven by 2 li-ions 18650 to 7.5V and doing about 309 torch lumens according to the hotrater program
The SSC holds its own against this 300+ lumen light, I would say the SSC Mag is putting around the same lumens as the overdriven magcharger bulb.
SSC Mag on the left and FM magcharger Mag on the right.
Edited with brightness all the way down
I am absolutely amazed! and to think it will give me 4+ hours of regulated brightness using 2 5000 mah Nimh C is just incredible! :rock:
The workmanship of the Icarus mod is awesome, skillful modder and an asset to the CPF community
Thanks Icarus! :goodjob:
AlexGT
AlexGT
