Aepoc
Alright...
I was recently given a Nite Tracker S/R LSI 500,000cp spotlight and was asked if I could make it better. The lights are used on the manufacturing floor of a large paper mill and have prooved to be unreliable. My goal is to brighten this light up and still have about 4 hours of runtime. My budget is no more then $100.
Inside I found two sealed lead-acid batteries, wired in parallel. They are 6 volts and 5 amp-hours capacity each. The bulb is a typical bi-pin configuration and is labeled as 20 watts. Almost everything is made out of plastic...
I would like to get away with just a bulb replacement but I am not sure what to do. Any suggestions??
