I have, well had, a 6 D-Cell Maglite. I used 6 Duracell D alkalines to power a Reflectalite GH-24 bulb. This light was left in the back seat of my car for use when I needed a big light for one reason or other. I used a Costo 12 pack of batteries to feed this light carefully repackaging the remaining 6 batteries the assure they did not mix up with used batteries. The first batch of batteries lasted for about two months before needing changing. I popped the second set in about four months ago and the light has seen regular use since.
Last week I when I tried the light it was completely dead. I noticed slight bubbling at the bottom of the reflector and naturally I'm assuming that light had rolled into a position in which it was activated. The switch was off so it must not have engaged all the way. I left the light as it was in the car untill I was able to get new batteries about 5 days later (yesterday.)
Now ready to bring new life to one of my favorite lights I opend the tail cap only to find the bottom battery had burst open. I banged the tube on the concrete unable to break the batteries loose and ended up damaging the end of the tube. frustrated I removed the head and the bulb and threw out the rest of the light.
Now this was one of my most useful lights and I plan on replacing it but I would like to know where things went wrong.
As far as I can tell the problem could be:
1) The 1.9 amps was more than the alkalines could handle. But I find that hard to swollow considering the Mag Xenon bulb is 1.7 amps.
2) Storing the light in the car which spends most of its days in direct Hawaii sunlight.
3) The light being left on running was too long for the the batteries to sustain such a high draw, or the batteries were over dishcharged.
Now I've ordered a second a second 6D from amazon and I need to figure out how I'm going to set it up.
Now I would like to continue to use primary alkaline batteries. and I hoping #3 is the problem. Then I could still use the GH-24, and just be more careful where I leave the light. I already spot in the car where the light is protected from accidental activation.
Now I #1 is the problem, my solution would be to change to led. I've been looking for an excuse to buy a Terrelux TLE-300M.
But if #2 is the problem I supose I'm going to have to ditch the idea of leaving the light in the car altogether, because I do not plan on changing battery chemestry. I really don't want invest in LSD nimh or any other hot car storage friendly batteries.
Please help, any input is greatly appreciated.
