milkyspit
Some preview pics of the PSM Chrominator Destroyer, a special X501bfx build for PoliceScannerMan... enjoy!
It all started with this...
Tri-bored battery tube, perfect for a 3x17670 series battery holder...
Fitting the 19mm reflectors heightwise into the Mag 2D head is going to a challenge...
Another look, top-down this time with the head itself removed from the light. To the right battery holder and tailcap are visible...
Starting to come together...
Head consists of 4x Seoul P4-USVOI emitters mounted in full-sized McR19 reflectors, which JUST fit heightwise... benefit is a decent hotspot in conjunction with excellent field of view, and gradual falloff of intensity moving outward from the hotspot... bFlex regulation circuit supplies flat output and supports a number of brightness levels, electronic lockout, low battery indicator, plus more...
The backing is a black textured surface reminiscent of a carbon fiber weave... and there's high temp silicone high density foam wrapped around the inner sidewalls of the head...
Emitters powered-up at their lowest level, showing the bond wires leading into the emitter dice and orange peel of the reflectors...
The beam is a good balance of throw and spill, designed to fill an entire area with center-weighted but still wide-angle intense light, while also managing some decent range...
Passes inspection so far!
