So after nearly 2 weeks of uneasy waiting, the beast has finally arrived !
Manufacturer specs:
The light came with no instructions, no warranty card except the contact information of the seller from HK.
The hexcore :thumbsup:
The hexcore is a nice feature.
Stainless steel bezel ?
Battery tray. Gold plated everywhere.
The battery tray is very well constructed.
Metal Switch
For some reasons, this metal switch has a slow tactile response. When you press it down, it takes a half second for the switch to come back up. Then the light comes after. In other words, it has no momentary-on feature.
Tailcap
Driver
Body tube
One word: beautiful. Type 3 HA is a plus. The threads are very beefy and well machined.
Glass lense with glow-in-the-dark O-ring
This is just the regular glass lense.
Size reference in hand
This is definitely a big light.
Outdoor beamshot (Distance: 126m or 413 ft)
I didn't have enough time to take better beamshots as after a few sample shots, the cop came and said the park is closed ( and she ran an ID check on me too :huh
. So sorry for the bad quality. The target is the white bench.
M2XC4 (coolwhite) vs. Ultrafire
M2C4 (P7) vs. Ultrafire
ULTRAFIRE 1300l( 7*SSC U2) VS. RL-2088 VS. M2XC4
Ultrafire RL-2088 vs. WE-Pilot Whale
Runtime Graph ( source:http://translate.google.com/translate?hl=en&langpair=ja%7Cen&u=http://www.bam-boo.cc/diynikki---2009nen-6tsuki/rantaimuultrafirerl-2088)
Initial impressions: The light is bigger than I thought. The light came with holster and lanyard and that is it. However, this light really impressed me with the quality in term of fit and finish except the minor tail switch issue as described above. The threads are very beefy and well machined. However, the threads are not very well lubed so I lubed them right away. The battery tray fits snugly inside the body tube without any rattling regardless any direction I shake it
. This light in fact delivers more punching power out the front comparing to my ex-Solarforce L950m (with 650 lumens OTF). This effect is caused by two elements: more intense hot spot and brighter spill.
Outdoor impressions: Man, this light has an incredible output. It has a huge bright hotspot and very bright spill too.Comparing to my ex-Solarforce L950m spill this light spill is noticably brighter. The throw is also very impressive because of its smooth reflector. Does it throw like Jetbeam raptor ? the answer is NO. However, the total amount of light it pushes out is insane. After being on for around 5 minutes (and the cop came) the head of the light got really warm, which indicates good heat sinking and being hard driven ? ( I hope).Overall, I'm totally happy with this light and I think it would save me lots of money for a long time until a brighter light comes out.
Manufacturer specs:
- Emittor: Osram 15w
- Manufacturer over-rated lumens: 1300 lumens
- Reflector: smooth aluminium
- Finish: type 3 HA aluminium
- Battery : 3*18650 ( side by side)
- Lense: glass
- Circuit: buck circuit
- Switch type: clicky switch
- Modes: High/Low/Strobe
- Water-proofness: yes
Metal Switch
Tailcap
Driver
Body tube
