That sucks abt the switch. Always a risk with these e-switches. Don't have an olight yet, maybe I'll wait....
OK, I just got the S1A today and been checking it out, wow so small and so bright for a little fellar. Well I am thinking there is a problem with the UI or switch. It will turn on and off single press, no problem. It will cycle through all the brightness levels and modes, no problem. Now the problem, when ever it is in high mode, it will not shut off with a single click of the side switch or change modes holding switch down, I have to unscrew the tail cap and all is good. On any other brightness settings than high, it will turn on and off no problem. I just noticed also sometimes while cycling through the brightness modes it will hang on high and stay there, have to unscrew tail cap to make it work right again. Think I have a funky switch or am I doing something wrong? Thanks for any help/advise. Update: now I'm really confused..lol. I checked the Olight lithium battery that came with it with my ZTS tester, 100% and voltage is 1.611v. So I thought I would try a standard alkaline and what do you know, it works flawlessly!! Why would it be locking up using the OEM battery and not the alkaline? Guess I'll ride it out for now and see what happens. OK update again. I did have it lock up once using the alkaline battery. Guess I'll email GG and see what they think I should do.
Hey olemil!
That is extremely unusual! We haven't seen a problem like this at all. Have you contacted GG yet? We can get you a replacement as well if that doesn't work out. Let me know! Thank you.
am looking forward to the copper titanium etc versions.
OP, have you tried it in the 2x configuration?
Thanks for an outstanding video review! You cover many topic that are often omitted on YouTube. I learned almost everything I need to know about this flashlight.
Your review compares favorably with most written reviews.
According to this review the 60s 600lm turbo mode only works a single time with a freshly charged 14500. Is that normal for the S1A?
[...]the original Fenix P1. A 1XCR123 "pocket rocket" with an "amazing" 55 lumens. lol Sounds pretty anemic now but that was only 10 years ago! [...]
[...]In any case I am able to go back to max power many times on the same 14500 cell provided I wait a bit between jumps.
The alkaline has a lower initial voltage than the lithium primary initially perhaps that is the problem.OK, I just got the S1A today and been checking it out, wow so small and so bright for a little fellar. Well I am thinking there is a problem with the UI or switch. It will turn on and off single press, no problem. It will cycle through all the brightness levels and modes, no problem. Now the problem, when ever it is in high mode, it will not shut off with a single click of the side switch or change modes holding switch down, I have to unscrew the tail cap and all is good. On any other brightness settings than high, it will turn on and off no problem. I just noticed also sometimes while cycling through the brightness modes it will hang on high and stay there, have to unscrew tail cap to make it work right again. Think I have a funky switch or am I doing something wrong? Thanks for any help/advise. Update: now I'm really confused..lol. I checked the Olight lithium battery that came with it with my ZTS tester, 100% and voltage is 1.611v. So I thought I would try a standard alkaline and what do you know, it works flawlessly!! Why would it be locking up using the OEM battery and not the alkaline? Guess I'll ride it out for now and see what happens. OK update again. I did have it lock up once using the alkaline battery. Guess I'll email GG and see what they think I should do.
Update: Yikes. I read your reply to quickly. "drops to around 60 lumens" I was thinking "drops after 60 seconds" (which it's supposed to do, I believe). So it drops to 60 lumens regardless of the battery voltage? That's strange. :thinking:
I thought so too, but IIRC I got like 58.9 lumens after the drop. I would assume what they are trying to do is let the light cool? Dropping to only 300ish might not do the job. Only speculation though.
