raggie33
*the raggedier*
- Joined
- Aug 11, 2003
- Messages
- 13,592
i finaly beat 20000 in 3dmark 2001 and there website is down been down for the last day or so.
gnef said:it really depends. it is possible that adding memory can give you extra startup time with BF2, but i think there are diminishing returns. what is the latency on your ram?
also, what kind of games are you playing? if they are mostly video intensive (which i think they are), the faster hard drive won't help it perform any better, it will help it load up faster if it loads from the hard drive. if it loads from the cd/dvd, then hard drive speed will have very minimal impact. i would say the bottleneck for games nowadays are the video cards, not the hard drives. getting a 10k or even a 15k will make everything in general be faster, but know that you will have to have a sata port or a scsi controller to use those faster hard drives. sata2 might be worth the wait...
from the looks of it, your video card is fairly recent too. are you having issues with your game? if so, i would first start with drivers and windows, then go to hardware issues. tweak the settings on your video card.
also, if you can, replace your memory with lower latency if yours isn't the lowest, that may garnish the most gains for you. faster hard drives are always nice, but again, the law of diminishing returns applies here too. the hard drive is overall the bottleneck with the computer, but with games, i think the video is moreso.
hope that helps...
V8TOYTRUCK said:I have no idea what the latency is..its OEM Dell so I am assuming not too good. I am guessing I have 2x512 in the 4 available slots. I am thinking about adding some Corsair Value Select 2x1GB
http://www.newegg.com/Product/Product.asp?Item=N82E16820145527
I am not having issues in the game, I play on the high settings with 0 lag. And that game has been called a vid card whore I was thinking adding ram and a faster HD would help map loading times which are about 30-45 seconds. (Loaded from HD I believe) and enable faster switching between game and other apps.
just a headsup newegg has a amd x2 4800 and a ecs mobo with nvidia chipset for 109
