1dash1
I just picked up an Ra Twisty 100T and have had difficulty trying to execute the 2-second factory reset.
There are two problem areas:
A. The flashlight has to be seated properly to ensure that it is not cross-threaded. This takes me at least a half-second to do. Indeed, this task is difficult to execute correctly in under 1 second. Nonetheless, properly seated or not, the clock starts ticking the moment the threads make electrical contact.
B. It takes approximately 6 quarter-turns to thread the light to the "on" position to trigger the factory reset. On a good run, the two-second time limit expires somewhere between the 4th and 5th quarter turn. On a great run, maybe I get a little past the 5th quarter turn.
Even after removing the o-ring to reduce resistance and cleaning/lubing the threads, I could not execute the procedure within the 2 second time limit.
So, my question for other RA Twisty owners is this: Have any of you encountered similar difficulties trying to execute the 2-second factory reset?
The only way that I can think of completing the factory reset within two seconds is by skipping step A. It's possible that I could beat the clock by slamming the head and body together and immediately twisting-like-a-madman. However, such a reckless procedure would virtually guarantee cross-threading sooner or later.
Please do not suggest that I go through the customization reset procedure, I have a boatload of comments regarding that non-user-friendly process.
Anecdotally, I'd also like to note triggering a faux-SOS mode during one of my failed attempts to beat the clock. The mode was an odd 5 short flash with 1 long flash (occasionally with 2 long flashes) flashing beacon.
Has anyone else encountered this mystery mode? Are there any other hidden modes?
