Member moviles has demonstrated that only one of the batteryspace IMR26650 can drive the SST-90 at 10A in direct drive, using a DMM with heavy gauge wire. (
In one of the other SST-90 threads). He still achieved 8A when the resistance of a PWM dimmer on full was introduced into the circuit. ElektroLumens noted in his
Blaster TNG sales thread that 4 good NIMH C or D cells drove the SST-90 above 9A.
Battery sag isn't the only challenge. The resistance of the wire used can make all the difference in delivering/measuring current. The same is true even if you are measuring with a clamp meter. If you do have a clamp meter that can measure DC current and the torch is already fully assembld, then you can still use the clamp meter to take the measurement by using a piece of 18ga wire at the tail cap. You can clamp it using an aligator clip at the end of the battery tube, and use a magnet or just hold it with your fingers to the battery end. The important thing is to zero the meter with the wire in place before turning on the flashlight. I've compared a high quality DC clamp meter to a very cheap (DX) DMM with 16ga leads and achieved the same results under an 8+ Amp load.
I thought I posted this here before, but now I realize that I make a mistake and posted it in
BriteLumens heatsink sales thread. (Apologies to BriteLumens).:
Unless a plug and play 9A constant current driver (single driver, not three in parallel) becomes available, then I'm considering a solution exactly as Fulgeo described, although in my version, it's three of AW's IMR26500 in a Mag 2D, wired all in parallel with the help of a custom PVC carrier that uses 16ga or 18ga wire in channels down the side. The only thing that has stopped me thus far is that I'm waiting for the warmer tint SST-90 to become available and more importantly, I'm waiting to see the "right" reflector or optic. On that note, I wonder how the 2D Mag LED reflector (deeper than incan) works. I'll bet it still doesn't focus well enough. (And it would likely melt at 9A.) If I already had all the other parts, I'd build one using the KD aspheric for now.
