beezaur said:
Ok, this is getting into a tangent, but a .40 S&W is not comparable to a .357 Mag.
A .40 S&W is less powerful than a .45 ACP, which is less powerful than a .357 Mag.
Yes, I agree that the hottest .357 is indeed hotter than the hottest .40S&W, but let's look at what a LEO might actually be
issued:
Speer Gold Dot
.357Mag 158gr. 1235fps 535ft-lbs
.40S&W 155gr. 1200fps 496ft-lbs
.45ACP 185gr. 1050fps 453ft-lbs
9mmL 147gr. 985fps 317ft-lbs
Cor-Bon JHP
.357Mag 125gr. 1400fps 544ft-lbs
.40S&W 135gr. 1325fps 526ft-lbs
.45ACP+P 165gr. 1250fps 573ft-lbs
9mmL+P 125gr. 1250fps 434ft-lbs
Not looking so different now, is it? All of them make wounds that look pretty much the same, and my only argument is that none of them are even close to a shotgun:
Federal
12ga slug 438gr. 1610fps 2555ft-lbs
The full-tilt 10mm really pushes the limits of case pressure (the .357 has far more case volume) which is hard on equipment but the real reason the low-powered "FBI load" 10mm came about is most agents were uncomfortable firing a .357 equivalent from a pistol that weighed half of what an N-frame revolver weighs. That's a great bear story too but I also wouldn't want to have to count on braining a bear with a handgun either
Just so you know, my very first handgun was a S&W .41 Magnum. I quickly found out there's no ".41 Special" or factory low-powered option as there is with .357 and .44, so it didn't see much use. Yes, I could handload them now, but at the time it was quite a handful and not very pleasant with its wood grips. Plus now it's just a shelf queen...
BTW the .357 is .38 caliber / 9mm
