I've got a Surefire KL3 on my forend. Works good, has held up to over 1000 rounds so far with no problems.
Are you using it indoors or out? My intended use is indoors almost exclusively. Reason I say that is range. I won't have any shots exceeding 15 yards under any circumstances. Is the KL3 enough at those distances?
SureFire's "L60L" LED Lamp Module for Classic WeaponLight forends such as the shotgun and MP5 forends is not yet released.
Replacing the L60's Z32 shock isolated bezel with the standard "6P" bezel so that the P60L can be used has meant that the L60 Lamp Module adapter collar/body needs to be re-designed for this new application.
Umm... it's all about learning to use the correct [SureFire] terminology... :nana:Umm... SF's website says the forend uses P60 and P61 modules... not L60 as Size15 has stated.
Please let us know how it goes.I'm going to try the P60L on mine tonight.
Go ahead and stretch the tailspring on the Malkoff. If you tear it up, I will replace it no problem. Also I have documented results from an objective third party stating that he has fired more than 9,000 rounds (AR 15) on one my dropins with no failure.
Thanks, Gene
