F89
- Joined
- Mar 15, 2014
- Messages
- 1,420
Plenty of Lego options.
I'm really liking my EDC2 on its original body.
So I got 28 minutes of runtime on the m91 with 2- 16340. Have you seen any spacers that would work in an md2?they draw 1400ma according to the official specifications and if I remember correctly we measured somewhere around that while testing, so li-ions should be able to handle that and more, easily
So Oveready doesn't have any cr123 spacers in stock, but for the price of a gallon of milk, I made this out of milk jug….most 18650 dellrin sleeves should work, but if you want to go really thin, you could try the Malkoff VME head with the 16650 body to make it as sleek and stable as possible.
( edit: I just realized the M91 is fatbody like the T-series, so won't fit the VME head, so scratch that part )
So Oveready doesn't have any cr123 spacers in stock, but for the price of a gallon of milk, I made this out of milk jug….View attachment 56040
If it wasn't for the 17.50 shipping I'd give it a shot.inventive the OR one was the only one I had that didn't suck, all others - including the Fenix one - did basically nothing. However, I see there's a LumensFactory one, I'd give that a try, they usually match the original manufacturers in quality and design.
I don't think they are fat body. I just put an m91bn in a 6p without an issue. It is definitely not as big as the m61 hot I have.most 18650 dellrin sleeves should work, but if you want to go really thin, you could try the Malkoff VME head with the 16650 body to make it as sleek and stable as possible.
yeah no worries, as you can clearly see by my previous posts I have changed my mind on this simple topic a few times already by the time I actually took the time to throw the setup in question togetherYou might have been thinking of the M91T? I think the TIR Malkoffs have a different set of dimensions than the reflector ones which affects their fitment in p60 heads.
EDIT: I realize you said exactly that in your post and I just repeated you like a goof. Gotta stop posting in my lunch break. Oh well, posting a pic of my MD1, DPC leggo to make the most of this post.
Are there any protected 18350 that will fit in an Md2?
M91b is definitely flood vs the throw of m61HOTv2Those are really interesting setups I hadn't considered in an MD2 body. Is there a performance advantage to using a M91B or T in a MD2 with a pair of 18350s or 16340s over a M61HOTV2 with an 18650?
Gotcha, I hadn't considered use case categories and was just thinking a straight performance comparison. But I can see the M91B would absolutely outperform the M61SHO, and also being able to get it in neutral tints is probably great. The more I see the SHO's tint the angrier I get, IT'S SO GREEN. The HOTv2 and the M91T differences kind of seem like a tossup, I'd actually be curious to see a break down of the two. They have the same emitter from what I can tell, and on paper have similar performances.M91b is definitely flood vs the throw of m61HOTv2
If you run the m91b on 1 cell, you won't get full output, whereas you will get full output with m61.
I would say an advantage of running an m61hot with 2 cells is a brighter low mode.
It is unfortunate that I can't get 2 protected 18350 in an Md2 for the m91b, but the run time only seems to be about a 10 minute difference from what I found on some runtime graphs, so it really is not that much different. I also don't have a taper with the 16340, it just shuts off, which I am ok with.
M61 hot on right
M91BN on left
I tried every configuration with the extender kits. It just does not work without crushing the springs too much.Gotcha, I hadn't considered use case categories and was just thinking a straight performance comparison. But I can see the M91B would absolutely outperform the M61SHO, and also being able to get it in neutral tints is probably great. The more I see the SHO's tint the angrier I get, IT'S SO GREEN. The HOTv2 and the M91T differences kind of seem like a tossup, I'd actually be curious to see a break down of the two. They have the same emitter from what I can tell, and on paper have similar performances.
I wonder if one of these would permit the Protected 18350s to fit?
https://malkoffdevices.com/products/malkoff-devices-md-body-extender-kit
