Techjunkie
I've dubbed this creation the Mark VIII for it's 8 emitter dies. It could have easily been named the Phoenix 'cause it rose from the ashes of the XVII-Ray or The Flashlight that Never Was
It's a modded, bored-out, Mag 3C crammed with:
1 5*CREE XRE refelctor and base module (DX)
1x Neutral White CREE MC-E in the center spot :EDIT: MC-E is now warm white to match XR-Es (post 7)
4x Warm White CREE XRE around the perimter (KD)
2x single mode 2.8A buck drivers 5.5-8.4Vin (DX)
2x Sony 26650VT 2500mAH LiNiCoMn batteries
One driver runs the neutral white MC-E wired as 4p and the other driver runs the 4 warm white XR-Es also wired as 4p. Power consumption measured at the tail cap is ~20 Watts so runtime is estimated at just under an hour. These regulators work really well too, maintaining brightness through the entire discharge.
In the photos, you can see that I originally planned to coneal both drivers within the base cavity. I even took the time to tap new holes around the outside so I could mount one of the drivers facing down on the inside. Every time I'd try to close the brass ring, the compression would cause a short. After many tries, I finally gave up and the drivers now reside inside the Mag neck where the bulb post used to be, hardwired to the switch. The top of the Mag tube pushes right up against the bottom of the base module for improved heat transfer. Same goes for the reflector to head and base.
The effect of the mixed tints arranged this way is entirely unique. The hotspot although still more intense than the spill, is much warmer. The neutral white MC-E in the center intensifies the spill considerably compared to stock 5x XR-E. It's kind of a wall of light with bright warm hotspot.
I have all the parts necessary to make its twin. Considering that I've already mounted the center MC-E (and tapped out the holes which are now unneccessary) that's probably what I'll do, unless I can think of something else to do with what I've already started, or chance removing the MC-E from the center spot on the second base.
