A few months ago I purchased a Trustfire 801 from a certain Hong Kong based web retailer. It is very compact for a 18650 powered Q5 light and perfect for my use. Problem is that the quality isn't that great. Are there any other manufacturers that make a very comapct 18650 powered light with the Q5 emitter. Now that I've tried the 18650 format I want more.
you say that ," It is very compact for a 18650 powered Q5 light and perfect for my use. Problem is that the quality isn't that great " but ,what it is like what ? can you give us a photo or link ?
yes , of course ,i have some stuff like that ! having a Q5 high power emitter light ! M3-2 .
it's spec as follow :
*Throw as Well as aluminum Within 372*250mm, Meters**
* Features a Mc-e Emitter, Q5 emittering rate ,silver core
* Up to 900 Lumens on high mode
* This light is designed for maximum throw
* Powered by a single 18650 or two cr123 * Voltage input 2.8-4.2V
* 5 Modes: Hi > Mid >blink>sos > Low
* Built in Voltage protection, will cut off at 2.7V
* Boost/buck circuit board.
* 2.8 mA on high mode
* 3 visibility
* It can tail stand
* Reverse clicky switch
* Always switches on to normal mode of 200 lumen (like standard 1 mode torch)
* Toughened ultra clear glass lens with 98% transmission rate
* Extra thick body for best durability
* 37.2mm x 25.4 mm smooth alumium reflector specially designed for throw
* Each light has its unique serial number engraved
Dimensions: 15.5 CM x 5.5 CM x 2.4 CM
Weight: 0.135KG
shipping info:
All orders except china the promote price is USD$ 42.8/pc FOB (guangzhou ) by T/T on MQO 1 .
china main land the promote price is CNY¥278 /pc rapid mail by T/T on MQO :1.
any prob. welcome to
[email protected] , always serive you !
M3-2 charming shape !
