BentHeadTX
HarveyRich said:I'm surprised that no one has commented on the complexity of the UI here. My only "problem" with what I've seen about this light is the UI complexity. One of the big issues in consumer electronics is making the UI of any piece of electronics user friendly. That's why some people never use the more advanced features of cell phones or can't program their DVD players.
This UI might be OK for the most hard-core users, but to the rest of the world it will be way too complicated. Can you imagine putting it down for a month and then having to read the manual just to get back into play with it?
Complicated UI? Turn the tail cap until it turns on default low, continue to turn until it moves to default high. Turn the opposite way until it stops to turn off. No problem.
Turn it on a month later and it acts the same way. The amout of complexity of the light is left up to the user. Now, if you don't like the light levels, things get more complicated--get out the book and program the light levels you prefer and enjoy the simple UI after programming.
All the extra goodies don't have to be used if you never use them. I am going to get the LF2 because of the programmability of light levels and really like the simple twist on and rotate to choose levels. No twisting on and off to change the levels. I'll keep a card in my wallet that informs me of the UI twists required to check the battery voltage since a keychain light gets variable levels of use.
I have been using a Fire~FlyIII for a year and it has a multiple twist program function to set the levels. I have not memorized how to do it (8 twists?) or how to change to different UI's. The only problem with the light is the body has to be loose to turn off so it can turn on in my pocket on occasion. If I get twist happy I can erase my programmed levels
The LF2 solves those problems and adds battery voltage indication. I can give the LF2 as a gift to my mom and leave the programming out of it and she would love the default levels. I think the default levels are alkaline friendly with the max programmable levels for NiMH cells. If you use NiMH in a keychain light, this is usually an indicator that you are either cheap (frugal) environmental conscience or a flashaholic.
As far as the $55 price goes, I find it funny that the cost would be a problem. The Fenix is cheaper but the LF2 has a better finish, has programmable levels, an easier twist to select levels instead of on/off/on twisting and--if you like--a lot of other things to play with. The SSC version is 4mm shorter than the Cree so the LF2 will only be 3mm longer than the LOD CE.
Just because a light can have a multitude of options does not mean you have to use them.
