SF E1B question?
ugrey
Dixie
If the E1B is on in low mode and I tap, not click, the switch does it go to high? Thanks for any response.
I just checked for you: when the E1B is on (regardless of mode) the only thing you can do is turn it off by fully clicking the switch. No response to half pressures or taps. :)
Thanks. I am thinking of how my Fenix lights switch between modes. I am trying to understand how SureFire does this.
The logic in E1B is the same as in Fenix (and many other lights), but Surefire is using a forward clickie and like Fenix it has no memory.
I.e.:
A full press: Turn on in high
A half press and then a full press: Turn on in low mode, with a flash of high first.
When on in high mode: Two full presses to get into low mode, with a short darkness between.
When on in low mode: Two full presses to get into high mode, with a short darkness between.
