I thought this was a well done article and exploration of "What is time?" by CalTech Theoretical Physicist, Sean Carroll
Time is Nature's way of keeping everything from Happening at Once.
:cool:
_
What I dont understand about Entropy is this: why does it speed up when the warranty runs out?
The past, present and future represented as a continuous whole. Time is
relative to certain things though. Life on Earth is dependent on time,
nothing lasts forever. So there needs to be a central basis on gauging time.
Humans use light to gauge the span of time passing. A "day" on Earth isn't
the same as a "day" in space. A day is measured by the Earth rotating 360
degrees in 24 hours. If you are not on Earth but say, Venus, your "day"
would consist of 243 Earth days. A Venus year is only 225 Earth days. Would you know how much time has passed without something to notify you? No. Now if you were able to travel at the speed of light, time wouldn't effect you the same. Time travels at nearly 300,000 meters per second. If a single human were able to travel at that speed(which would disintegrate you, and even if we could everything would become invisible) they would stay young while everyone back on Earth would age at a normal pace. The person traveling at light speed would return to Earth to find that a few minutes passing in Space equaled around 30 Earth years.
Sorry it's hard to read. I'm new here. Thanks for letting me talk your ears off.
Time is what you make it. :shrug:
If you accept the premise I would make the case that two questions posed by the interviewer answer each other.Wired.com: So if this universe in the middle is just sitting and nothing’s happening there, then how exactly are these universes with arrows of time popping off of it? Because that seems like a measurable event.
Carroll: Right. That’s an excellent point. And the answer is, almost nothing happens there. So the whole point of this idea that I’m trying to develop is that the answer to the question, “Why do we see the universe around us changing?” is that there is no way for the universe to truly be static once and for all. There is no state the universe could be in that would just stay put for ever and ever and ever. If there were, we should settle into that state and sit there forever.
It’s like a ball rolling down the hill, but there’s no bottom to the hill. The ball will always be rolling both in the future and in the past. So, that center part is locally static — that little region there where there seems to be nothing happening. But, according to quantum mechanics, things can happen occasionally. Things can fluctuate into existence. There’s a probability of change occurring.
would consist of 243 Earth days....
