wquiles
Re: Stupid question time
Awesome, glad it arrived safely
If you close the pack too lightly, you will not get the optimal contact between all cells and the pack's electrical contact points, and you would therefore have a higher resistive path for the current, or even intermittent behavior.
I am sure that Eric will chime in sometime today, but the best description would be "very snug". As you start applying pressure, the nut basically gets to a point where is stops moving easily - to go past this point requires a lot of additional force, and it does feel like you are "compressing" the cells after this point. That is when you stop - you don't want to feel like you are compressing the cells.
These two short videos shows that I do get the nut "snug", but that I am not trying to crush the cells either:
PhD-M6 Video 14: Side loading of protected 17670 cells
PhD-M6 Video 15: Removing the protected 17670 cells
Will
I second all the compliments that have been given so far. :twothumbs:twothumbs:twothumbs
Have only had a few minutes to play with it so far. :thumbsdow Work gets in the way of a guy's hobbies at times.
I do have one question, though: How tight is the thumb nut supposed to be to make contact? I even shaved off the black plastic on the Neg. ends of my cells and have to really reef it down to get it to function.
Can't wait for dark!!!!!!!!:naughty::naughty::naughty::naughty:
Will
