What cut-off / parting tool do you use?
wquiles
Texas, USA, Earth
I am subscribed to a couple of Yahoo Groups, and one of the members of the 12x36 group talks highly about an Iscar Do-Grip patting tool, which seems to produce a very interesting looking curl which ends up being smaller than the groove being cut, due to the unique geometry it uses:
I have to admit that I am intrigued since with both my HSS and Carbide parting tools I do have a little bit of a problem with the curl/chips being caught/pinched in the groove I am cutting :(
Any of you using something like this? What do you guys use?
Will
As prevoiusly posted, I use a simple 1/16 inch wide , 1/2 inch tall HSS parting 'blade'. I've ground a bit of rake on top as well as side clearance. I did not manage to create that neat V shaped chip breaker but simply use a short bristle brush to clear chips. I use Tap Magic Gold when parting.
I hone the cutting edge with a diamond fingernail file.
I seldom have any problems parting steel or aluminum. It is NOT a white knuckle experience.
Daniel
Iscar tooling is nice ... awesome might be more accurate ... but their toolholders & inserts are proprietary (meaning expensive), unlike the more generic parting tool inserts made to the (now expired) Iscar patent - GTN, GFN, GTR, etc.
http://www.carbidedepot.com/Dynamiclanding.aspx?CategoryID=4290
On smaller machines, .087" - .094" is about maximum width (listed as a 2 or 2.4). With the tool extended as little as possible, and the insert tip at dead center (or no more than .010" below center), parting should go well.
On the mini lathes, the smallest width inserts like a GFN1.2 or GFN1.6 work well. They are pretty tiny, and a little delicate, but make use of the limited hp available.
As prevoiusly posted, I use a simple 1/16 inch wide , 1/2 inch tall HSS parting 'blade'. Daniel
+1
I use the same thing. Perfectly happy with it.
That said, if I was doing allot of parting in steel, I would probably invest in an insert system, most probably Sandvik as I am 2 miles from a major Sandvik distributor and use their inserts and like them allot.
I picked up a similar part-off took from Enco for like $60. It's made by Manchester and the inserts where $8 each. I have parted probably 20+ pieces of titanium and lots of aluminum. I'm still on the same first insert.
Mac
just bumping this back to the top to see if the Iscar is still the go to for parting
At least for me, YES. I have now 3x Iscar parting blades. Look at my thread on the parts catcher for a video of it on action:
http://www.candlepowerforums.com/vb/showthread.php?341488-Cut-off-parts-catcher
And a recent page on my own website with various videos, two of which show the narrower (I think it was like 1.5mm) cut-off blade from Iscar:
http://www.atdms.com/custom_parts_page2.html
Will
thanks Will what size blade do you recommend i get lost when i search for them there are some many different ones
It is a little bit of a catch-22 since it depends on the holder you have, and the holder depends on the size of your tool post (A, B, or C series).
Generally speaking the more narrow the insert the better, but narrow inserts typically can't cut really deep (2-4" diameter). The narrower the insert the less force is needed, which is good for smaller, less rigid machines.
With what I know now, I would start with a narrow iscar insert, such as the 1.6mm series (0.063"). Do a search on ebay for "Iscar 1.6". Then you need an insert blade, and a blade holder, etc..........
Will
That is the "challenge" with Ebay if you "want" the cheap prices I pay - you have to wait until the right parts come up.
The other alternative (which given how cheap I am, I hate to do, but sometimes had to do to get "exactly" what I needed), is that you can go to Travers (and many more on-line vendors) to shop for the Iscar blades, and then buy the inserts cheap on ebay.
Will
Yup, the 26mm one. You then need a cut-off blade holder that fits your tool post size.
But you can get the smaller one (19mm, I think), such as this one that I use often:
Will
I have a Iscar parting blade SGIH 26-3, I would like to know if anybody could tell me if the GFN 3 and GFR 3 inserts will fit this blade. Thanks for any help.
Have you tried Googling for it?
A quick search on Google brought a page from Travers that states:
ISCAR Self-Grip Parting & Grooving Blades - MODEL: SGIH 26-3
Overall Length : 4.33"
Use Insert : GTN/R/L 3
Blade Height : 0.842"
So based on that, the GFN or GFR will not work with this blade.
Will
I wasted way too much time stumbling around on the Enco site looking for, Insert Type GT\*-3, now I see. Seemed like some secret code I couldn't crack. That page on travers is much easier for me to decipher,even includes related items like, GTN 3 inserts, how about that. Thanks, it's crystal clear now.
