flip
I got a 28mm aspherical (DX calls it an optical) lens from DX and installed it in a Surefire nitrolen bezel. The lens was too large so I had to sand down the outside edge with a Dremel tool. Once the lens would start past the 1st threads in the bezel, I pushed it all the way in. I did not use a retaining ring. The tight fit against the threads seems to hold it fine.
I also used an R2 drop-in from DX. I removed the reflector and sprayed several coats of flat black high temperature grill paint.
The hot spot seems to be a little tighter. There is no spill at all.
The comparison shots are of this light and another Surefire with a stock DX R2 drop-in.
